03-11-2024 10:54 PM
I just purchased $34 plan Canada wide 2 days ago, but I want to upgrade to Canada-US $40, since i will be going to USA next month. If I "change on renewal" will my plan change at the end of this 1st months cycle OR after 90 days.
Thanks in advance.
Plans
03-12-2024 07:53 AM
@Deltapi How much were you charged for your plan? I seem to recall a couple of people mentioning a 90 day option that wasn't advertised appearing when they selected that plan. If you were charged $34 plus tax you are on 30 days, if you were charged $102 plus tax you are on a 90 day plan.
03-11-2024 11:21 PM - edited 03-11-2024 11:30 PM
Depends on your cycle. Login to your account and it will tell you when the next renewal is. If you subscribed to a 90 day plan, it won't renew into the new plan for 90 days minus time elapsed. But as mentioned, the $34 plan didn't have a 90 day option, so it should be 30 days.
03-11-2024 10:58 PM
at the end of the 1st month cycle? Thanks! @fixin
03-11-2024 10:58 PM
@Deltapi if you change on Renewal, your plan will kick in after the end of 30 days. There is no 90 for these 2 options.
03-11-2024 10:57 PM
@Deltapi - At the end of the cycle it will change.
