11-05-2022 02:54 PM
Changed my plan this morning payment went through it says my account is active but I cannot receive calls or make calls or have any data. Is their a system outage ????
11-05-2022 06:16 PM - edited 11-05-2022 06:19 PM
@Jesse_jukes91 wrote:In Alberta.
I am also using PM service in Alberta. I changed my $40 plan to the new $40 15GB plan earlier without issue.
There are two members reported this morning with plan change to the lower price plan to save expense in the current high inflation enrollment.
May I ask: Did you change to a lower price plan?
Edit: You answer will allow PM IT department to fix the issue quickly. Thanks
11-05-2022 04:24 PM - edited 11-05-2022 04:30 PM
@Jesse_jukes91 wrote:Changed my plan this morning payment went through it says my account is active but I cannot receive calls or make calls or have any data. Is their a system outage ????
This is the third message thread that I've seen in the last few minutes describing similar loss of service after a scheduled plan change while the account still reports a status of active. I've contacted Public Mobile to try to see what I can find out. Please feel free to tag me within the next few days to ask if I have heard anything else about this issue.
11-05-2022 03:08 PM
@Jesse_jukes91 If you have another compatible phone handy, perhaps try your SIM in it to rule out a device problem. Then insert it back in your phone and reboot. Otherwise you'll need to contact support using the links provided earlier.
11-05-2022 03:03 PM
Yes I tried
11-05-2022 03:02 PM
In Alberta.
11-05-2022 02:59 PM
Perhaps a local issue...where are you at generally.
Did you try restarting phone ?
Try switch Airplane mode ON..then OFF.
11-05-2022 02:59 PM
Hi @Jesse_jukes91 did you try reboot your phone?
try also reseat your sim card once
if still not working, it is possible the plan change caused problem. open ticket with CS:
at : https://publicmobile.ca/chatbot.
First type Contact CS Agent,
from the list of , choose "Other"
finally click the the blue link about submit a ticket
11-05-2022 02:59 PM
@Jesse_jukes91 Could be some outage in your area perhaps? BC is experiencing outages because of the windstorms from yesterday. Are you in BC?
First try rebooting the phone.
