Changed plan by mistake
Sweetridge
I accidentally changed my plan by mistake. I want to keep my current plan.
Dale
dabr
@Sweetridge   If the plan you had previously was grandfathered, then you wouldn't be able to schedule a change back to that plan as it's no longer offered.  Otherwise, just schedule the (Change at Next Renewal) option now as suggested.
Meow
How did you change your plan? Did you change it Now or you schedule change on next renewal?
If you changed NOW then you have been charged full amount. Otherwise you can modify (I think) your plan change.
I doubt agent will reverse your decision of plan change but you can always try to talk to agent and explain your mistake.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
@Sweetridge was the plan already changed today or did you just schedule a future plan change on renewal?
If a future plan change, you can go back and cancel it
But if the plan was already changed amd PM took money for the new plan, the I am afraid you cannot do much.  PM is a prepaid provider.  And before you forget,  make a schedule plan change in next renewal to change back to your old plan
Gunner123
@Sweetridge hi how does one make a mistake and change their plan?
