09-16-2021 05:10 AM - edited 01-06-2022 03:23 AM
i just changed my phone number on self service by choosing the new number since yesterday. It is shown in the account with my new phone number but when I tried to call the new number, it said “6UT1 the number you reach it is not in the service”. I tried to reset the network and it’s still didn’t work. Please help. Thank you.
09-16-2021 12:50 PM
try to Changing Your Number again,
You can change your phone number up to 4 times every 30 days after you’ve activated. To change or transfer your number after activation, go to your Self Serve Account here link, and:
and Reboot your phone.
what is mean for Rebooting the phone means to turn off your phone about 2 minutes and turn it back on.
and if still not fix it please you Have to Contact Customer Support Agent by CS_Agent ,
Explain your issue they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck
09-16-2021 08:14 AM
@Grace123 It does sound like there was an issue with the Change number
did you try to put your SIM in another phone ?
Or if you don't have a second phone, at least try to power off the phone first. Wait 2 mins and then power it back up and see if it works.
If issue still persists, you can open a ticket with PM to have it sorted out. Or a quick way is to request another Change number request. But keep in mind you can only change number 4 times in a month
09-16-2021 06:06 AM
@Grace123 wrote:i just changed my phone number on self service by choosing the new number since yesterday. It is shown in the account with my new phone number but when I tried to call the new number, it said “6UT1 the number you reach it is not in the service”. I tried to reset the network and it’s still didn’t work. Please help. Thank you.
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
IF still issues after above...
Did you select a new phone number, or were you transferring one from another provider?
If transferring a number, were you porting a number from an account that is currently active?
Or, from what provider?
IF a new number, and you are not committed to it, try changing the phone number again. Log out of self serve. Reboot phone.
One more thing, do you have an iphone?
Set up your phone number On your iPhone:
09-16-2021 05:46 AM
It seems the number change has failed or the SIM not provisioned properly.
You'll need to contact Customer Service for help, either via Chatbot or Private Messaging:
