Changed email
AngusM
I've changed my email since I last logged into my account. How can I get into my account now.
HI@AngusM
did you submit a ticket with PM agent and ask them to change to another email you have access?
if you have trouble with the Chatbot way, please message them directly here to open ticket
AngusM
Ok I went through all of that and they need to sent a code to verify account. We can do that because the phone is out of funds and it wont let the call to go through to add funds.
Hi @AngusM
just submit ticket with agent and they will help to change to a working email
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
AngusM
I no longer have access to that email
GiraffeHat
Do you still have access to your old email? If not, maybe try your old email with your password. Or do you mean you updated it on public mobile?
