Change plan
Menno27
Noticed the $35 plan now offers more data
why wouldn’t it automatically be added to my plan.
or do I go through the motion of changing to $35plan?
@Menno27  You need to register a credit card or Visa debit card.
Setting up AutoPay means that you earn $2 every 30 days!To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
 @Menno27 : Just the obvious...you have autopay set on right?
You won't see the full details until it actually changes. Unless you did an immediate plan change.
Menno27
It doesn’t show the extra 500mb for auto pay option
was hoping to get to 3gb
mh1983
PM has great deals but it's a no frills service. It's on users to manage their accounts. Be grateful you can change to whatever plan you want at any time. I haven't seen that level of freedom elsewhere, especially when it comes to promo plans for new users vs. existing ones.
HALIMACS
@Menno27
Here’s the process for changing plans, first login to Self Serve to this screen:
Then, click Change Plan:
Then select desired Plan:
Then choose Change on Next Renewal Date:
 @Menno27 : You need to "go through the motion" of doing it yourself. Make sure to set it for your next renewal.
