01-18-2024 05:52 PM
It's my understanding that Add-On data only gets used after plan data is used up. Can this order be changed?
I'm about one week into a billing cycle and have about 7 days left on some Add-On data purchased in the middle of the previous cycle. I'd like to use up this Add-On data before it expires.
01-18-2024 06:56 PM
regular plan data gets used first. When it limits out, then your data add-on goes to work. If your plan renews before using all add-on data...then regular plan data takes over again. Good possibility of remaining add-on data will expire before it gets used again as it has a 30 day expiry. If you find you use up all regular plan data, consider upgrading to a plan with more data....way better value than add-on.
01-18-2024 06:15 PM
@SalsaCycle wrote:It's my understanding that Add-On data only gets used after plan data is used up. Can this order be changed?
This is a matter of how the system is programmed. Customer support agents have no access to changing that type of thing as it's a different department that handles the back end systems.
01-18-2024 06:04 PM
Tough question... I believe you have to use your allocated data first and then it will continue using add-on.
Lets see what other have to say.
