Change my email and password
tajachaschowy69
I can't get into my self several acounnt I donyd have acssac to my Gmail and forgot password and I need to add a new payment
2 REPLIES 2
fergiedroid
I would definitly try to recover your Gmail password.
This can be done at: https://accounts.google.com/signin/recovery
There you go...you figured it out. 🙂
If you have your 4-digit PIN you can use the 611 service. Actually it might even happily take your money even without a PIN. Even easier if you have a cc on file and it works. Otherwise you can use a voucher.
Maybe one of the newly-minted Oracles could remove your blank post.
Otherwise, you'll need to contact the moderators here.
Send ONE (1) private message to them here and include your phone number and PIN to minimize back and forth identity verification delays.
Forget your PIN? Then you'll need 3 of either of these pieces of information you used when you signed up: full address, birthdate, last 4 digits of CC you might have used, email address on the account, alternative phone number you might've entered when you signed up. Or, in addition, either of these to get to 3: last payment amount and date, last add-on bought and date.
And of course your question/problem.
Then hopefully they will get back to you as soon as they can between M-F 9-9 (ET) and Sat-Sun 9-7:30 (ET). But it could be up to a couple days.
Depending on your notification settings, you would get an email notifying you of a reply. Get back here and see a red blob over the little envelope in the upper right of your screen and click on it to see the message.
