11-09-2019 11:08 PM - edited 01-05-2022 07:55 AM
Hi,
Phones
11-10-2019 01:00 AM
@AE_Collector wrote:Yeah I could see that happening. SIM changed but needed a restart to work. Instead the Change SIM function used again and now the new SIM is toast.
AE_Collector.
The phone wouldn't say no sim unless sim was inserted with phone turned on. The reboot could make the service work but wouldn't be needed if the sim wasn't already in the phone.
11-10-2019 12:51 AM
AE_Collector.
11-09-2019 11:50 PM - edited 11-09-2019 11:51 PM
@inboxofjeremys By using the change sim card option multiple times it's possible that you also deactivated the new sim. Best to submit a ticket as I recommended above.
11-09-2019 11:40 PM
@inboxofjeremys That's a tough one. Did you restart each phone as you inserted the sim?
Can't see two sims being defective. Get in touch with @CS_Agent if you don't get it working; they may help you with getting a refund for the sim you purchased and maybe a replacement sim if indeed the two sims are damaged.
11-09-2019 11:34 PM
Tried my iPhone 8, Asus M1, wife's iPhone se
11-09-2019 11:33 PM
@inboxofjeremys wrote:Yes, tried 3 now, my spare,wife's and sons
@inboxofjeremys Submit a ticket to Public Mobile and include the new sim number that you used.
11-09-2019 11:32 PM
Sounds like your phone (sim socket) MAY have been damaged? What kind of phone Is it?
11-09-2019 11:29 PM
The issue is I pulled my SIM card out of my phone and it got damaged, I bought a new SIM card and went to my account and clicked change SIM and it said successful but my phone still says no SIM, I tried another phone and it says no SIM as well. I have now tried 4 times and each time it says SIM card change successful but carrier never showed up on either of my phones
11-09-2019 11:27 PM
11-09-2019 11:19 PM
@inboxofjeremys No sim means your device is not detecting the sim card. Sounds like it might be that the tray or device was also damaged. Did you test the new sim in a device that is currently working?
11-09-2019 11:16 PM
Will restart your phone make any difference?
