Change my Address
Phuc
I can't change my address. The system keeps sending error. No number to call. No helpdesk to chat. So frustrated!
2 REPLIES 2
@Phuc
Are you using the PM app to enter your address?
Go to the Account tab>Manage Login (Manage by Eversafe) click on right arrow then change.
HI @Phuc
is your address a new address on Canada Post or Google Map?  I think the system use Google map and it is trouble for new addresses
But support agent can help to enter the address for you.   please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
