02-14-2021 05:41 PM - edited 01-05-2022 05:17 PM
Hi good day!!! I like to ask, how can I change my new mobile no . to retained my previous number. Hoping for your response..thank you
02-14-2021 05:53 PM
@Rosella wrote:Hi good day!!! I like to ask, how can I change my new mobile no . to retained my previous number. Hoping for your response..thank you
Hi @Rosella , if it is not a Telus or Koodo number you should be able to transfer it yourself through your SELF SERVE account here, go under "Change Number"
Then choose the "Transfer..." option.
The number you are wanting to port over should be ACTIVE.
02-14-2021 05:49 PM
Hi @Rosella ,
IF you are Transferring A Number From TELUS Or Koodo (Including Formerly PC Mobile)?
If you wish to transfer an existing number from TELUS or Koodo (including formerly PC Mobile), you will need to first complete your activation with a new number, then reach out to our Moderator team here in order to transfer your existing number to Public Mobile.
02-14-2021 05:42 PM - edited 02-14-2021 05:42 PM
Here is the HDI on porting your previous number.
