Change in plan
elsiep
I tried to change my plan to the 30 doller one with 500 mb and unlimited Canada wide talk and international texting and message with the voice mail it says it did it on the 23 of April  but I don't know if it really did is there a way customer support can check that out cause it looks like I am paying more
9 REPLIES 9
elsiep
Nothing has changed
elsiep
It says 45 but not the 30 is no longer there so I put it to the 35 but I press the button and nothing happened like it is making me so mad why all this why couldn't they keep customer service number would of been better I am getting so up set with this it driving me nuts
hycm53
Log in your self service account, under account status, click plan details, then you will see your current plan details.
elsiep
But on the overview it still says the 45 plan
elsiep
No in my plan I was trying to change it but it change on the billing part but on the overview it says 45 plan
elsiep
It says 45 doller plan but I changed it and then it says on Apr 3rd it is 30 one Screenshot_20190504-172425.png
elsiep
It says it was the 30 doller plan on the 23 of April when I checked 3 days ago then there was a 38 doller charge then a 10 one and on April 8 it says the 30 doller one then it says something about system error Screenshot_20190504-172425.png
Alex888
@elsiep Are you referring to the charges on your credit card? Those charges include the tax, which is not included in the total cost of the plan.
@elsiep  - When you log into your self serve portal and check your current plan, what does it say?  Also, if you post a screenshot of your payment history (removing anything personal), someone here can help descramble it for you.
