06-06-2025 09:57 AM
06-06-2025 10:46 AM
06-06-2025 10:33 AM
hi @Eleen
but you have not told us your device model and location for us to help more
But if you want PM support agent to help, you can go directly by submit ticket
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
06-06-2025 10:30 AM
@Eleen wrote:I have tried all the the mentioned
Does talk and text still work as expected. Any chance you can try your Public Mobile sim in a different cellphone ?
06-06-2025 10:28 AM
06-06-2025 10:07 AM
hi @Eleen
your voice call work? where your location?
try reb0ot phone, Reset Network Settings . Try sim on another phone
and check Telus outage:
https://www.telus.com/en/bc/outages
