10-28-2024
01:57 PM
10-29-2024
12:06 AM
computergeek541
Anyone else having cellular issues in Calgary or surrounding area? Wifi works fine but cannot get access to text or email or make some calls on cellular.
10-28-2024 02:05 PM
All good over here on the east coast, but i have read some others were experiencing this issue late last week. I would suggest as others have mentioned, rebooting your phone, making sure your plan is paid up to date, and if those dont work going into settings and resetting network settings. If all the above does not fix the issue, you should message a PM agent using this link:
10-28-2024 02:00 PM
@Katcando Can you first confirm your account is active and not suspended
Also check
Outage map in your area:
https://istheservicedowncanada.com/
if account is active and no outages in your area and rebooting the phone won’t help get support to help fix
10-28-2024 02:00 PM
HI @Katcando
check the outage here:
https://www.telus.com/en/ab/outages
try reboot the phone. Try changing the network mode to 3G and see if it works
if same, report to PM, message them here
