Cell Number
Kaiyogan
I’d like to subscribe to Public mobile,I was a Wundle customer and was wondering if I can keep my old number?
2 REPLIES 2
HI @Kaiyogan
generally yes, most number can be ported around.  But please confirm first , use this link (it is Koodo, but PM uses the same Telus system as Koodo)
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
if it says yes, then you just need to get the Wundle account number, activate, and request to bring in your number at Step 5 of the subscription process.  Make sure you enter the phone number as well as Wundle's account number
@Kaiyogan  First check that your number can be ported . And if yes you can port it over in activation in the PM app
Check to see if # can be ported
