Carrier issue
Aman83
My carrier is showing up as public mobile and my iMessage is showing up as verifying. I will not be able to receive any messages from my previous carrier. Which I need to properly switch over.
2 REPLIES 2
Chalupa_Batman
Hey @Aman83
You need to take out the Public Mobile SIM card and put in your other carrier card that you're porting from to get the text message. If you don't do it within 1.5 hours, you'll have to call a certain number to re trigger the text again.
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
HALIMACS
@Aman83
You only need to receive SMS from prior carrier, not MMS or iMessage.
Reply "YES" to that message, then replace with the PM SIM card, reboot your device, and the number port will occur.
