05-18-2024 11:18 PM - last edited on 05-19-2024 11:20 AM by computergeek541
Cant login, system asking code sent to email when i complete this task its asking for Code sent to my phone which i have no access at this moment. In instructions to reset password its saying either or but not both for otp
05-18-2024 11:23 PM
so, you cannot receive the code on your phone?
if you really cannot receive the code, sms or email, you will need to engage support. Private message CS Agent at:
05-18-2024 11:01 PM
you have no access to the phone and you cannot receive the 2FA code?
you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If send email option is not there, you can Try these workarounds, it could bypass the SMS and open up the email option
If none of those workarounds helps, please open ticket with PM support. Private message CS Agent at:
05-18-2024 10:59 PM
