05-13-2017 02:04 PM - edited 01-04-2022 01:46 PM
I switched over from wind .yesterday at 4pm over 12 hours. I had switches my wind number over to public mobile . not receiving incoming calls, text and internet is working. Please help as soon possible.
My email or number if want is mxxxxxxxxx9@ gmail.com. thanks
08-06-2018 09:32 PM - edited 08-06-2018 09:33 PM
@alexsv wrote:hi, just transfered number from rogers to public mobile, cant get any incoming calls, outgoing call ok.
please help to solve this issue.
thanks.
When you request to transfer a phone number, the situation that you have descrived ia exactly what is supposed to happen. When you say "just transfered" I'm assuming that it had been only a short period of time since you made the request and the time you posted your message. The transfer has not yet been done unti Rogers releases the phone nunber to Public Mobile. After that, incoming calls should start working, and your Rogers service will stop working. Until that time, you can still receive your calls on the Rogers service
According to CWTA wireless to wireless phone number transfers are aimed to be completed within a 2.5 hour time window. Since it's been about 3 hours since you typed your message, can you check again?
08-06-2018 06:18 PM
thanks.
07-12-2017 05:16 PM
07-11-2017 01:58 AM - edited 07-12-2017 08:49 PM
I had issues with no service for just about 3 days but the issue got attended to 2 days ago and I know have PM service up and running well on my phone.
Moderators are backlogged up to 3 to 4 days and are attending everyone’s concerns on a first-come basis. However, I am sure that by tomorrow morning they will much faster respond timing as the backlog has drastically decreased since.
It's good that you emailed the mods but be sure to not forget to email PM as well through the following link: https://publicmobile.ca/en/on/get-help. Click Contact Us to access the email form process. Be sure to be as descriptive with your issue as you can and they will get back to you within 48 hours, but usually a lot sooner.
Once again, the longer than usual wait time was due to backlog caused by the FM promo that lured in a more than usual number of sim activations for PM.
When I did that I got service by the next day evening and had no issues since
07-10-2017 01:57 AM
I am very frustrated- stuck port since June 30 with no incoming calls (routing to Freedom) and the porting team shows the number is with Rogers (it was ported to Freedom successfully). Two mods attempted to fix it last Mon and Tues with a 24-72 hour estimate but that has passed a few days ago.
I'll be leaving Public Mobile Monday around midday if this isn't fixed - sent two PM, an email and now this post in the last day.
Unfortunately I will go back to Rogers who employs technical teams who can be reached by the customers should something need fixing. I can't wait any longer for this debacle to be sorted.
Mod team - can someone in porting get in touch with me now?
07-10-2017 01:39 AM
@Danoishan that's great, and thank you for the update! What changed to allow it to start working?
07-09-2017 07:56 PM
07-09-2017 05:14 PM
It's been unlocked and its a note 4
07-09-2017 02:20 PM
@Danoishan okay sorry if you've mentioned this previously but are you 100% sure your phone is carrier unlocked? That is, not locked to the Freedom Mobile network? If you purhcased the phone from Freedom and did not get an unlock code from them or a 3rd party service, the phone will be locked to Freedom's network. Also, what is the phone's brand and model?
07-09-2017 02:14 PM
07-09-2017 12:55 PM
@Danoishan is this still an issue? It can take a few hours when porting (or even several days if you've ported from a landline or a VoIP provider). If it's been that long, and a reboot doesn't resolve the issue, please send a private message to @CS_Agent with your Public Mobile SIM card number, the phone number you're trying to port in, the full name of the account holder at your previous provider, and your account number from there. They will be able to resubmit the port request for you. If you're not sure how to private message, please see the second link at the bottom of this reply.
07-08-2017 03:16 PM
06-26-2017 12:00 PM
@westcoastsurf Although I agree with you but now I have been waiting for close to 2 days without incoming calls and outgoint texts. So my patience is running thin now![]()
@Shazia_K I hope you look at my case soon enough!
06-25-2017 04:39 PM - edited 06-25-2017 04:40 PM
According to MarieHelene's update here: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Frustrations-with-PM/m-p/161838/highl... the mods are working tirelessly to get on top of their backlog, replying to private messages on a first come first serve bases. They expect a longer than usual respond times.
FYI sending them multiple private messages about the same problem slows the system down because they have to look at each one of them and then need to figure out whether it's been solved or not.
We understand your frustrations and are thankful for your patience!
06-25-2017 04:27 PM
06-24-2017 04:00 PM
I have the same issue. Ported my number and since yesterday I cannot make calls and all incoming calls goes to voicemail. Porting a number should take less than an hour. I sent more than 5 private messages to Mods, but none has replied or solved my issue. It's very frustrating and disappointing.
05-16-2017 05:40 PM
Hello,
You can delete your post yourself if you would like to, but normally we don't as it can always help other customers out! 😉
Why would you want to delete it? 🙂
Simon
05-15-2017 08:59 PM
05-15-2017 03:21 PM
@Mike40999 Moderator coverage today is 9AM - 9PM, eastern time zone (Toronto/Montreal time zone)
05-14-2017 07:24 AM
05-14-2017 07:18 AM
05-14-2017 01:20 AM
05-13-2017 02:49 PM
@Mike40999 also: there's no need to post your question multiple times.
05-13-2017 02:46 PM - edited 05-13-2017 02:47 PM
@Mike40999 I've merged your duplicate threads and edited your posts to mask part of your email addres. In accordance with community guidelines, please don't post any personal information to the community, since all threads are publicly accessible.
Contacting a community moderator (Public Mobile support employee) via private message is the best way to get help for this situation. Please see the two links at the bottom of this reply if you're not sure how to located and private message a community moderator for assistance.
EDIT: thanks @xCameron94x for pointing out the duplicate threads and private info.
05-13-2017 02:11 PM
you're duplicating posts
this is how to private message a MOD
05-13-2017 02:10 PM
05-13-2017 02:05 PM
05-13-2017 02:03 PM
you shouldnt post private information in here, as it is a public fourm. It seems like you're in a stuck port. You should message a moderator with all relevant account info.
@Shazia_K I have tagged one for you
05-13-2017 02:02 PM - last edited on 05-13-2017 02:45 PM by srlawren
05-13-2017 01:42 PM
