08-12-2023
01:15 PM
08-12-2023
01:43 PM
computergeek541
I bought an e sim and a 56$ plan and the cellular data said it’s connected to telus but the app says to gain full access verify the phone number u selected but the device is not getting any text messages and cannot send any text messages the esim is Broken please return my money or verify my phone number
08-12-2023 01:23 PM
Private message worked resending code dosent change anything thanks
08-12-2023 01:23 PM
08-12-2023 01:21 PM
Links private mrsssage with no spot for message or to do anything
08-12-2023 01:20 PM
Clicking the support ticket link goes to private message with no spot to enter it and clicking resend code dosent work I’ve tried
08-12-2023 01:16 PM
@Bjayy Tap resend code a few times you should get option to send code to email instead . If no luck please submit ticket with support to help you fix
private message To CS_Agents click
VVVVV Link below VVVVV
