08-12-2023 12:46 PM
Just switched my plan to the new Canada US plan but I keep getting tithe message “cannot activate cell network use wifi or turn cellular data on”. Cellular data is on so??
08-12-2023 01:21 PM
@GWS Sometimes a good old reboot is all that’s needed to fix glitches . We happy to hear you go it all sorted out . Enjoy all that extra data 🙂
08-12-2023 01:19 PM
I’m in Canada. I did a phone reboot and that solved the problem. Thanks!
08-12-2023 01:17 PM
Phone reboot worked like a charm thanks!
08-12-2023 12:54 PM
I rebooted my phone and that worked. Thanks
08-12-2023 12:53 PM
Phone reboot worked - thanks!
08-12-2023 12:50 PM
Are you in the states?
08-12-2023 12:48 PM
@GWS Try rebooting the phone or reset network settings see if that helps
