Cannot swap sim
Deeschmizz
When I go to edit profile and change my SIM card number and press save changes It just erases what I wrote and turns it into zeros.   I've tried this on 2 different phones now , please help.
HI@Deeschmizz   the sim card you want to change to is a brand new one never activated?
You can try again with Incognito mode, but since you tried different phones already, it likely won't work
So, the next step is to open ticket with CS agent and have them to manually change sim card for you
open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
@Deeschmizz - You lost or damaged your existing sim card ?
Do you currently have your phone listed as lost/stolen? If so, go back and take the lost/stolen feature off. Log out, then try again through a tab in incognito mode. Can you then swap the sim card number on your account?
For reference see "How To Change Your SIM Card" at the bottom of that link @Timer provided in their post.
If continuing to have issues ask CSA help with the SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
edit
Timer
@Deeschmizz
