02-02-2024
06:52 PM
02-02-2024
09:23 PM
computergeek541
In the past few weeks I'm unable to send texts from home. Most the time the icon shows that i don't have a data connection. I have wifi (if that is an option) - but doesn't use it. I'm using the $25. plan.
02-03-2024 09:35 AM
I would turn Cel Service off and strictly use Wifi at home that way it’s not bouncing back and forth between services. Contact Support Will help with this too.
02-02-2024 07:16 PM
But i did try several of the many networking options and none fixed the problem
02-02-2024 07:09 PM
there'll be some Motorola users give us some suggestions shortly...I'm an iPhone guy myself.
02-02-2024 07:05 PM
Motorola g7 power
Set to support LTE/GSM etc. No option for setting to G?
02-02-2024 06:54 PM
what kinda phone you using ? Have you trying using 4G, LTE or 5G to see if either improves things ?
