01-31-2019 03:10 PM - edited 01-05-2022 03:12 AM
Outbound texts are showing in my usage history, but no one I send them to are receiving them. Likewise, I do not receive texts that others have sent me. How can I fix this? I transferred my number to Public Mobile from Virgin Mobile today.
04-25-2019 08:02 AM
Hi,
I sent several this issue but still did not works
i changed from bell and the number is same
and i already activate the public mobile and works everything except incomming call and SMS message.
our company unlocked and already provide it to you and you already got it.
======================< It's mail =====================================
A note has been placed on your account, authorizing you to port it to a new carrier/personal account.
Contact your provider to complete the transfer. Please provide the SAP account # 531746905.
the ball is your side. not sure what the problems
can you please fix it ASAP . that is very important to me now.
if you need to call ( 1 226 606 8099 : my son's phone)
becasue my phone (647 622 5934 : not working of the incomming , which is the problems to fix)
Thanks.
Ray Jungrae
01-31-2019 04:48 PM
@matt4411 wrote:
@sandpublic wrote:
@matt4411 wrote:
@sandpublic wrote:Did you powercycle your phone after the port was completed?
I turned it off and removed the SIM card for a minute, then turned it back on, if that's what you mean.
Yes, what number is showing in your settings--> System -->About Phone?
The number I've always had, that I transferred to public mobile.
If you put in your old sim does it still work? If yes, the it means the port is not !00% done on the Virgin side.
01-31-2019 04:10 PM
@matt4411Stick in your old sim card, from your old provider and use that until it stops working, then you know the port is completed. At the moment, your calls and texts are still being routed to your old provier. Public mobile has set your outgoing number to the old number, but in terms of everywhere else, your old phone is still the active one
01-31-2019 04:09 PM
01-31-2019 04:09 PM - edited 01-31-2019 04:21 PM
@matt4411 wrote:
@RobertQc wrote: @matt4411Did you just activate? When did you activate? Did you just port your number here? Are INCOMMING calls working? Can those people who are unable to text you call you? How many people have this issue, how many people tried to text you?Yes, I just activated today, 3-4 hours ago. Yes, I just ported my number. Incoming calls do not appear to be working, I get a busy signal when I call my mobile with my home phone. The people who are unable to text me are also unable to call me. At least one person tried to text me.
It appears only outgoing calls work.
@matt4411Ok, this was the key piece of information. Since you said calls were working before I ruled out the porting process. Their texts are still going to your old sim card from your old provider. It takes some time, every hour or so remove your battery / restart your phone. It can take time on your first port over and there can be weird issues for a short period of time. Usually hours for cell phones, sometimes days for voip/land line.
If the issue continues you may have a partially completed port but most often ports just take a bit longer. One of the moderators can take a look, see if they need to do something to move it along. Click this to send them a message
01-31-2019 04:07 PM
01-31-2019 04:03 PM
01-31-2019 04:00 PM
I am having the exact same issues. Cannot send or recieve SMS messages, or make calls. I sent messages to the moderators over 2 hours ago and no one has replied. I haven't been able to use my phone in two days. It sometimes connects and then stops connecting.
01-31-2019 03:45 PM
@matt4411 wrote:
@RobertQc wrote:
@matt4411 wrote:
@RobertQc wrote:@matt4411Have you tried clearing your messanger app data/cache? Are you using the stock messenger? What phone / os version are you using? Have you tried rebooting your phone? If you log in to self serve, usage history does it show the texts there?
I don't know how to clear my messenger app data/cache. Yes, I am using the stock messenger. I'm using a Xiaomi Mi A1 on Android 9. I have tried rebooting my phone. When I log into self serve, it shows my texts in usage history. What is "self-serve"? When I log into my public mobile account on the website, I can see the text messages I sent in my usage history.
@matt4411Okay, if they are showing up in the public mobile account (self-serve) both incoming and outgoing, then it sounds like a network issue and I suggest sending a message to the moderator team. Click this to send them a message. and letting them know your texts are not being delivered or received but show up under usage history. I know there is some trick they can use to "reset" your sms so hopefully that fixes it.
Incoming texts from others are not showing up in usage history, just outgoing texts I send to others and incoming texts I send to myself.
01-31-2019 03:31 PM
01-31-2019 03:29 PM
01-31-2019 03:23 PM
01-31-2019 03:22 PM
01-31-2019 03:20 PM
01-31-2019 03:19 PM
@RobertQc wrote:
@matt4411 wrote:I'm on the $25 unlimited call and text plan. Calls are working.
@matt4411Is your phone set up to send SMS as MMS, and maybe your mobile data / apn is not configured? The SMSC number for Public Mobile is 16475800172. Make sure you input that number into your message center option on your phone. Depending on your phone... Messaging=>Settings=>Text(SMS) Messages=> SMSC Setting. Then input 16475800172
I don't know if my phone is set up to send SMS as MMS. My APN is configured, as far as I can tell; the settings are the same as the APN settings I found on this site. I can't find SMSC settings.
01-31-2019 03:14 PM - edited 01-31-2019 03:16 PM
01-31-2019 03:13 PM - edited 01-31-2019 03:14 PM
01-31-2019 03:12 PM
01-31-2019 03:12 PM - edited 01-31-2019 03:12 PM
@matt4411 wrote:Outbound texts are showing in my usage history, but no one I send them to are receiving them. Likewise, I do not receive texts that others have sent me. How can I fix this? I transferred my number to Public Mobile from Virgin Mobile today.
@matt4411Is it just SMS? Are you able to send MMS? How is your calling/data? Does texting yourself work? Have you tried inserting your sim in a different phone? When you send a message, does it say "sending/failed" or does it appear to send?
01-31-2019 03:11 PM
Hi. What plan are you on? Are calls or data working?
GC
