06-04-2024 06:15 PM
Hi it’s almost 1 month since I cannot send and receive SMS messages. Is there a solution for that?
06-04-2024 06:34 PM
@Alexpascan Some weeks ago there was a problem with SMS texting for new customers. Public Mobile was having to fix this individually. They did fix it generally eventually but some who were affected before that may still have a problem. You would need to contact customer service as @HALIMACS suggested.
06-04-2024 06:18 PM - edited 06-04-2024 06:18 PM
They’ve had problems with MMS.
Does your calling and data work?
You could try the SIM card in another device to see if SMS works.
