Cannot receive or make calls
nahraf_ila
Hello ,
I recently switched my plan from Canada-wide to Province-wide calls but cannot receive or make any calls at the moment.
Please advise
Thanks
@nahraf_ila wrote:
Thanks. Will do. Sorta new to this, but how can you exactly tell who's a staff member?
Here are the details: http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/All-you-need-to-know-about-our-Communit...
nahraf_ila
Try removing the sim and rebooting your phone.
If that doesn't work, it might be something in the backend. So get in touch with one of the staff member: http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
nahraf_ila
Yes, it says active. I removed the texting option but data seems to work just fine.
NDesai
What about texting or data? Does your self-serve account say active?
