03-24-2024 11:03 AM
Hi,
I ported my number from a internet phone service (voip.ms) to Public Mobile last night and now when it asks me for full access, it requires me to receive an SMS to complete verification. Issue is that my previous service with voip.ms didn't let me receive SMS so I am not sure what to do. Can I call them to verify? If so, what is the number?
Thank you
03-24-2024 11:34 AM
hi @Camera4617 OP @Gosu won't get any incoming calls and text until port is done. Before it is ported, OP VoIP line will be fully functioning like before (so no text) and try Pm line can only make outbound calls and text and no inbound at all
But after port is done, of course the PM line will be fully functioning
03-24-2024 11:33 AM
Yeah its enabled. I've contacted support to see what they can do about it.
03-24-2024 11:31 AM
Sure, but that doesn't mean you cannot get any SMS and this one might work. Did you enable it?
03-24-2024 11:29 AM
Ok thank you. I did send an email out to voip.ms support to request the porting out to Public Mobile. Perhaps I'll give it few more business days and come back for support if it hasn't resolved. Thank you for reply!
03-24-2024 11:28 AM
So to keep it simple, voip.ms service lets you make calls through wifi but when it comes to receiving SMS such as bank/2fa verification messages, it's not able to receive it. They even state it on their website too. There is more to it but it gets more technical.
03-24-2024 11:19 AM
How come you are not able to receive a SMS on voip.ms?
03-24-2024 11:15 AM
hi @Gosu you don't be able to login until the VoIP port is done since you cannot receive text on that VoIP kind af the moment. And porting from VoIP carrier takes around 3 to 7 days
anything you want to login My Account to check might need to go through CS agent until port is done
03-24-2024 11:15 AM
Porting from VOIP service usually takes several days to complete. Unlike mobile lines which takes a few hours.
You could contact customer service agent to see status of your activation/porting.
Either submit a ticket vie then following link:
Or send a private message to moderator through the following link :
