Cannot make or receive calls
wadia301
When I try to make calls it says call declined and I can't receive calls either.
DDM69
Submit a ticket.  It took a day, but it was fixed and calling now works for us.
HALIMACS
@wadia301
There have been issues with calling of recent.
Try rebooting your device, resetting network connections, or toggling airplane mode on/off.
If that DOESN'T work, contact the support group if your account status displays as "Active"
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
