07-29-2023 07:55 PM
I signed up for a plan today but when trying to login eversafe is sending the code to some number i dont recognize.
Need help!
My Account
08-01-2023 09:41 AM
@maro7 have you had an account with Public Mobile before?
07-30-2023 10:59 AM
@maro7 wrote:No email option comes up
@maro7 if you cannot log in try the 'Forgot your email' option as a workaround: https://eversafe.id.telus.com/user/forgotemail?locale=en&ForceAuth=true
07-29-2023 09:20 PM
@maro7 You can always port number in afterwards . Notice transfer number under the first red circle in pic . This is screen shot of your my account . On profile page
Change # on profile tabs
07-29-2023 09:11 PM
had to pick a new number it wouldnt give me to option to port
07-29-2023 09:10 PM
Did you port your number over to PM or did you pick a new number?
07-29-2023 08:18 PM
@maro7 .then please submit ticket with support to help
privrate message To CS_Agents click
VVVVV Link below VVVVV
07-29-2023 08:12 PM
07-29-2023 07:56 PM
@maro7 Try tapping resend code a few times . You may get option to send code to email instead . If still no luck . Please submit a ticket with support to help you
