12-04-2021 11:13 PM - edited 01-04-2022 05:02 AM
My security question doesnt work and I cannot log into my account to add date. I need help resetting my password.
12-04-2021 11:16 PM
You'll need a CSA for that.
12-04-2021 11:15 PM
Contact a CSA.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
12-04-2021 11:15 PM
@Angela11211983 wrote:My security question doesnt work and I cannot log into my account to add date. I need help resetting my password.
Please open a ticket through https://widget.telus.tiia.ai/publicmobile/publicmobile.html and type in "forgoot security question answer".
