01-14-2022
01:31 PM
01-15-2022
12:19 PM
Dunkman
Dear Public Mobile: I recently activated my new public mobile account; payment has been verified, and the account is in good standing. I inserted the SIM into an iPhone X, and i cannot get any service. The phone displays "Public Mobile"; I have manually selected the public mobile network in "Cellular" and carrier coverage, but the phone doesnt connect to network. I restarted and followed all of the steps. Please help me connect to the network, thank you!
01-15-2022 04:34 PM
thanks for your help - working directly with the agent now!
01-15-2022 03:48 AM
You have an iPhone. First connect to wifi and check for any software updates. Then you need to connect to iTunes and update your carrier profile. You will be prompted to sign in with your Apple ID at some point and you should be good to go....lol...ok I went and looked to be sure....
. Insert new working SIM - do not turn phone on (if SIM is already in, turn off)
2. Connect to computer with USB cable.
3. Start iTunes if it doesn't auto run
4. iPhone will switch on. Wait until iTunes registers it and checks for updates
5. Install the carrier profile update (if offered, if not, go to step 6)
6. Disconnect and restart.
Above courtesy of @softech since I am strictly an android user. However you may find this thread courtesy of @CalgaryBen a very informative read for Apple device users.
https://productioncommunity.publicmobile.ca/t5/Get-Support/FYI-iOS-and-APNs/m-p/323118#M162906
01-14-2022 08:17 PM
@lewallen wrote:Dear Public Mobile: I recently activated my new public mobile account; payment has been verified, and the account is in good standing. I inserted the SIM into an iPhone X, and i cannot get any service. The phone displays "Public Mobile"; I have manually selected the public mobile network in "Cellular" and carrier coverage, but the phone doesnt connect to network. I restarted and followed all of the steps. Please help me connect to the network, thank you!
@lewallen to rule out a phone or SIM/account issue, can you try your SIM card into another compatible phone?
Reboot the phone with the SIM card inside, performing a reset of the network settings is a good thing to do on a new activation or change of phone.
Does it work in another phone?
Other things to ensure when porting or changing phones:
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
IF still issues, ask Customer Support to check your account; 2 methods to reach them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
01-14-2022 02:05 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck...
01-14-2022 01:59 PM
THANKS - so far nothing is working, manual, automatic or otherwise. I need help diredctly from customer support, thanks
01-14-2022 01:50 PM - edited 01-14-2022 01:51 PM
@lewallen , you should not have to manually connect to the network. Have you tried a network reset to see if that helps.
01-14-2022 01:42 PM - edited 01-14-2022 01:45 PM
Can you go into About phone and check for updates.
Edit to add:
If you need to Contact Customer Support Agent by CS_Agent and explain your issue to
them and they can solve your issue, they are nice Service Team, they will help you 100%.
Only they will do this for you.
Here's How To Contact Customer Support Agent,
Good Luck.
