Loop
yukinamis
Thank you.
EB0
@yukinamis
use the app to change the phone number.
if you don’t have referrals or points, you can sign in with a new account, get the benefit of new activation only plans.
will13am
@yukinamis , I don't think it's a major issue if anyone used you phone for a bit.  You can use the activity to track down who might have used your phone.  The greater concern is the knock on effects like possibly using 2FA to take over accounts.
Sansan
@yukinamis  system running slow today.
Clear your browser to see if that will help.
But here's the link if it's not working.
https://myaccount.publicmobile.ca/en/account/profile/update/phone-number
hi @yukinamis
what suspicious activities? if phone calls to a number ends with 4001, you are safe. That's just calls to voicemail, PM logs all those calls and so no need to worry
But if you still try to change number, try using Incognito/private/secret mode on your browser
Also try using Public mobile app, one of the two ways will work
if not, then submit ticket with PM  agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
