05-03-2020 11:32 PM - edited 01-05-2022 10:38 AM
I cannot change the plan.
Since there are no options provided on the 'Change my plan' page.
Then, How can I change it?
05-03-2020 11:52 PM - edited 05-04-2020 12:09 AM
Go into your self serve account click on Change plan.
Scroll down and you will see the 25.00 plan, click on it.
Then click on change plan now.
(edit)Note: if you change plan now mid month it will charge you for that plan immediately. @z10user4 pointed out it is recommended to change your plan just prior to your next renewal.
Make sure that you have funds in your account to cover them.
05-03-2020 11:36 PM - edited 05-04-2020 12:11 AM
@Joyjooy Try waiting an hour, clearing your browser history, go to private/incognito mode and try again to change it. Thanks. Stay safe.
Here's an article on switching plans https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
05-03-2020 11:39 PM
@Joyjooy wrote:I cannot change the plan.
I am able to go into my account and select change plan and it will bring up the plan options. I wonder if some regions are experiencing issues with the self-serve
05-03-2020 11:46 PM
Hi there, I want to change my plan to the plan of $25/month for next month. However, there was no option provided on the 'Change my plan' page. Could you help me to fix it? Thanks.Mengyuan.
05-03-2020 11:55 PM - edited 05-04-2020 12:10 AM
@Joyjooy it seems there is a problem with the website right now. this is the screen I get when trying to go to the plans and add-ons tab. best to try again in a couple hours or even tomorrow morning
edit: browser used in incognito/private mode is working.
05-03-2020 11:59 PM
05-04-2020 12:00 AM
@Joyjooy Just keep trying every hour or so hopefully the website will be back up soon.
05-04-2020 12:00 AM
05-04-2020 12:01 AM
I'm in Toronto and it works. So it's probably regional.
@Luddite , Oracle's duplicate post.https://productioncommunity.publicmobile.ca/t5/Self-Serve/Cannot-change-my-plan/m-p/537996
Please merge. Thanks.
