05-25-2017 03:08 PM - edited 01-05-2022 02:08 AM
Maybe lost today....canit find it , along with my sim card inside the phone, so will you guys send me a new sim card with the same number?
Service
05-25-2017 06:36 PM
Try calling your phone and locating your device with google play if that doesn't work assuming you have data enabled.
05-25-2017 03:15 PM
Correct 🙂
05-25-2017 03:12 PM
you'll need to buy a new SIM card, and then update your account information. You should also say that your phone is lost/stolen in your self-serve
@Shazia_K is this correct?
05-25-2017 03:12 PM - edited 05-25-2017 03:38 PM
Hi @hxsports,
The steps are simple 🙂
1) Go in your selfserve and report your phone lost/stolen (under the "Plan and Add-on" tab)
3) Reactivate your service in the selfserve when you receive your new SIM and enter the new SIM number (under the "Plan and Add-on" tab).
Obviously, you'll need a new unlocked phone that works with Public Mobile. Don't worry, you'll be able to keep your number (as long as your account doesn't stay inactive for more than 90 days).
If you find your phone in the meantime, save the SIM to activate a friend and earn the referral reward, or keep it somewhere for the next time you lose your phone. Unactivated SIMs don't expire.
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
