10-29-2023 09:38 AM
Hi, my current subscription renewal shows this message. "Subscription will renew on Nov 27, 2023." In case I cancel the subscription on Nov 26, 2023 I hope I still have till Nov 27, 2023 11:59 PM EST (midnight) to port out my
Service
10-29-2023 11:02 AM
I haven't heard anything different for quite a while so perhaps the system has settled on 12:01am eastern of the second date. (note eastern)
Turning off subscription is really just the autopay. If you have a balance then the plan would renew. If no balance then it would not renew.
10-29-2023 09:57 AM
there are two different ways of PM showing cycle dates , different account different ways and that was confusing
to best answer your question, can you login My Account, go to transaction log and tell us which date PM last charged you? Then we can answer your question correctly
But as I said above, Do not wait till last day to port out. There could be porting problem here or with you new carrier, best to start the porting around Nov 22. You might loss couple days, but you don't have to worry about pay a full month if any issues
10-29-2023 09:55 AM - edited 10-29-2023 09:57 AM
If you port out before that date there will be no charges, but if you want peace of mind, disable auto subscription.
10-29-2023 09:52 AM
So, will PM charge my Credit Card on 27 Nov at 11:59 PM (midnight) or 26 Nov at 12:01 AM.
10-29-2023 09:50 AM
HI @anotatesid
remember you need an active account to port out, so, you need to port out before Nov 27., but I would not wait till the last day, in case system issue. I suggest to port out around Nov 22 to give couple days just in case, also, drag it till the latest to use the service as much as possible on PM, remember, there is no partial refund here
10-29-2023 09:43 AM - edited 10-29-2023 09:44 AM
Just disable your subscription and you won't be billed after November 27.
@anotatesid I would be inclined to port out a few days before renewal just in case there are any problems with the port that need sorting out. Do not cancel your PM subscription before you make the port request and accept the authorization text with a YES, your PM account needs to be still active for the new provider to be able to acquire your number otherwise it may be lost. Your PM account will automatically close once the number is ported out.
