03-31-2026
03:42 PM
03-31-2026
04:40 PM
computergeek541
Hello,
I am not able to login my account, and I want to cancel my cell phone plan with Public Mobile. Please advise.
thanks
03-31-2026 03:48 PM
Thanks
03-31-2026 03:45 PM
Hi @Carol_N we have sent a private message in case you need support, please double-check your community inbox.
03-31-2026 03:44 PM
HI @Carol_N
yes, you are supposed to login My Account and disable Autopay yorself
but if you cannot login and want to cancel the account without porting the number away, you can simply ask PM support agent to remove your credit card. You can submit ticket by direct message:
03-31-2026 03:43 PM
Ask PM to help with the login.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
