Cancel subscription without having the sim
tamar2
Hello,
I don't have the sim available but I still would like to cancel my payments. How do I do that?
Thanks,
Tamar
tamar2
Thank you wrote to CS agent
HI @tamar2
you don't actually need your sim , you have couple ways
you can still login My Account to  go to Payment, Manage Subscription and disable Subsribed.  For the 2FA , just choose "Didn't receive code?" and choose email to get the code
you can also call 1.-855-4PUBLIC and use your account pin to disable Autopay
last, you can submit ticket with CS agent and ask them to remove the credit card or just help to disable autopay
tamar2
Thank you I'll do it
tamar2
Hi,
Thank you but I can't login w/o the sim thats the problem
Tamar
@tamar2  You can ask support to remove the credit card on file right away
send a  private message   To CS_Agents click
Chalupa_Batman
HI @tamar2
If you log into your account and click on subscription, click the toggle to the left to turn off the sub and it will be cancelled. Also, if you were to port your number to another provider, that would also cancel the subscription.
If you're unable to figure it out, please contact a CS Agent to assist via this link and keep an eye on that mail envelope in the top right corner for their reply.
