Cancel Subscription
bird25600
2 REPLIES 2
Yummy
- Remove Subscribed switch and in 90+ your account will be closed, number lost
- Port out your number to another provider and your account will be canceled immediately.
@bird25600  Log into your account and unsubscribe is one way , or if you port your number out to new carrier it will cancel your account or finally you ca ask support to remove the credit card on file right away in that case
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
