Canadian Tire code is too long
kent2
i just purchased a 30 dollar card from Canadian tire but the code on it is 16 digits while it states 12 digits on the public mobile site.  How do i use this code
maximum_gato
@kent2
To the best of my memory I dont recall Canadian Tire offering $30 public mobile vouchers. There is also no 16 digit # on the example given ( which was my voucher at the time). Are you sure it's a pm voucher vs a PC Mobile or Petro Canada Mobility voucher?
@dust2dust
Funny I never noticed that the PIN# and redemption # were the same before? 🤔
thanks @dust2dust , updated
dust2dust
While the redemption # is the same as the pin# on the example...just keep focus on the pin #. It's the pin # that should be used. There is also stupidly enough a voucher # given. That's not the one to use.
@kent2   this image could be old, but check if you see a PIN  # on it like this:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Voucher-Catalogue/m-p/479165#M40236
HI @kent2   Yes, it should be just a 12 digits code not 16.
you sure it is a Public Mobile voucher? did they gave you a wrong one?
check if there is other code on it
