Canada - US unlimited minutes
07-27-2024 07:48 PM
If we are down in The US and we have the unlimited Canada - US plan can we call down in the states or is it just if we are in Canada we can call the US
Plans
07-27-2024 10:37 PM
Yes, you can still make the call if you are in the US
07-27-2024 09:32 PM
you said you have a Canada-US plan, then you can use the data in US too
for voice and text, you can call from Canada to Canada and US, and you can also call from US to US and Canada
07-27-2024 07:56 PM - edited 07-27-2024 07:58 PM
what plan do you have?
if your plan is $34 50 GB Canada-US plan
Data can be used in Canada and IS up to 50GB, once you consume all data, you will not be able to use data till your next renewal
07-27-2024 07:53 PM
Is the data only Canadian?
07-27-2024 07:52 PM
You can call Canada and US if you are in Canada or US
In US , you can call both Canadian and US numbers without any extra charges
