07-27-2024 08:59 PM
i am looking for my sim card number. my rogerrs has 20 digit but public mobile aske me to provide 19 digit. what should I do?
07-27-2024 10:23 PM
Yes I am aware of that but I was referring if it was a Koodo prepaid service since OP is porting from Rogers…they can ignore this step.
07-27-2024 09:37 PM
i still see it as OP is transferring from Rogers. , but of course, best for @aliagha to clarify
07-27-2024 09:34 PM
@slusagm wrote:
@BKNS27 wrote:
- Note that your previous service is Koodo prepaid…you will need to pick a temporary number and contact the CS_Agent to complete the porting of your old number.
op is transferring from Rogers
Actually, the OP is asking how to change their network from Rogers to Public Mobile. We could speculate that the OP is trying to transfer from Rogers to PM but so far everything the OP has said points to the theory they have a Rogers SIM card and want to use it on the Public Mobile network. That is how I'm reading it. 🙂 And until the OP shares more information, everyone here just keep throwing out posts. The ball is now in the OP's court to share more information to get help.
07-27-2024 09:30 PM
Hello @aliagha
@aliagha wrote:I said that I would like to change my operator network from rogerrs to public mobile.
Can you please show me where you said this?
You asked where to find it. I provided you info to find it.
If you require more help, feel free to share more information about what you're trying to do so the other members here will help you. Good luck.
07-27-2024 09:26 PM - edited 07-27-2024 09:27 PM
to contact support: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-27-2024 09:26 PM
how can I access to CS_Agent?
07-27-2024 09:20 PM
Make sure your Rogers account is still active to port your number over to PM.
The steps must be followed in exact order if you are porting your number over to PM:
07-27-2024 09:17 PM - edited 07-27-2024 09:17 PM
@aliagha wrote:access is denied
The message in the link isn't supposed to be accessible. It's only a placehodler to indicate that I had removed a duplicate messgae from this thread.
07-27-2024 09:12 PM
access is denied
07-27-2024 09:07 PM
@aliagha wrote:i am looking for my sim card number. my rogerrs has 20 digit but public mobile aske me to provide 19 digit. what should I do?
Sorry, but your Rogers SIM card cannot be used. You'll need a buy a Public Mobile SIM card.
07-27-2024 09:07 PM
07-27-2024 09:06 PM
07-27-2024 09:03 PM - edited 07-27-2024 09:04 PM
Umm... this is Public Mobile. Not Rogers.
As you can see by this picture. There are 19 digits.
