Canada-US Promotion
fox_33
Looking to switch to new $34.00/month plan 50GB within Canada and US Data.
Question 1 - if I switch will I be converted over to new points system from the legacy rewards system?
Question 2 - this plan means I never need to buy US data for $30 that only lasts 15 days? I am able to use my phone for calling and data in Canada or the US with no issues?
PM_5G
@MacCherry You are incorrect...
All Canada-US Plans are available to current customers now.
Refer to my previous post below for any clarification....
MacCherry
PM_5G
Data in not unlimited - it is capped so you would need to get a data addon after allocated plan data.
I had similar concerns / questions about the Canada / US Promotional Plans...
Collected all the info and posted clarifications I received...
Click below and many of your questions should be addressed and answered!
**** !!! Click Here and Check out My Post on Canada / US Plans !!! ***
atticuss66
Do you know if you use the entire 50g....data will be throttled????   Or once it's used, thats it.
@fox_33
1. You will stay on the legacy rewards system and receive the same rewards discount every cycle
2. Yes, you no longer need to buy roaming add-on, you can use data/text/voice services in US just like you are in Canada
