03-24-2026 08:51 PM
Good evening!
Does the $40 Canada US Mexico plan mean that you can use it from US and Mexico or just call to US and Mexico?
03-29-2026 12:24 PM
Is data working? Texting? Which model phone are you using?
Might be worth manually selecting another Mexician carrier (instead of Telcel) to see whether that works.
03-29-2026 10:23 AM
I set up my plan and have data roaming on and connect to Telcel in Mexico. However, I cannot make a call. Have tried adding +1 , 001, straight number, etc. I get a message that tells me some phones are not in service or equipped to receive calls.
03-24-2026 09:59 PM
To use data, ensure that you’ve enabled Roaming in cellphone settings.
03-24-2026 08:52 PM
it is a true roaming plan. You can access data/text/voice in US and Mexico just like you are in Canada. And for calls, you can call Can/US/Mex from all 3 countries for free
