06-26-2023 12:26 PM
extra- on the 90 day plans for opting out of the points system entirely… can we get the option to pick a different way.
06-26-2023 12:32 PM
@Proxima @If your on the old rewards you can keep them when switching plans . Just don’t switch to new points system . I just switched to the 20GB $39 plan and kept my old rewards check it out
06-26-2023 12:30 PM
First, if you are on the legacy rewards system, changing to 90 days plan won't affect your legacy rewards
If you are on the new Public Points, then you will be earning points
I don't think you have a choice to get $5 instead of points
The Public Points opt out clause is just a regular message for all rewards system, it allows people to opt out all the rewards program for different personal reasons, like religous.
06-26-2023 12:27 PM
There is no such option. Don't opt out though. You get nothing. I'm not sure if one could ask to get back in.
