10-10-2025
03:02 PM
10-10-2025
05:57 PM
computergeek541
I have the can mex us plan ,when I am in mexico do I need to change my settings to use my phone
10-18-2025 09:51 AM
Thank you ,easy when someone knows,I didn’t
10-10-2025 04:17 PM
to call a Cdn number while in Mexico use +1, area code, number. Others have success using *1, area code, number.
10-10-2025 03:07 PM
hi @ampowel
most likely not
but you need to make sure you have Roaming Mobile Data turned on
also, make sure you connect to Telcel or AT&T, if not and you have trouble using the phone, try manual connect to those networks and try changing network mode to 4G or LTE
10-10-2025 03:04 PM
