09-29-2023 07:38 PM
09-29-2023 07:48 PM
@Aakong , try doing a network reset on the new phone.
09-29-2023 07:40 PM - edited 09-29-2023 07:42 PM
you should just be able to remove sim from old phone and install it in the new phone. Restart phone and you shouild be good to go.
added...
use link to check if phone isn't blacklisted....https://www.devicecheck.ca/check-status-device-canada/
