Can’t sign into my account!!
atiller79
I have an email that is no longer existent, so I have no way to sign into my account to change the expiry date on my payment card because it sends security code and I have no way to access it!!
@teresabartlett5 may I know what exact error message yiu got,?
You have active service now? or when  you last got working service from PM??
try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
teresabartlett5
Can't get in to my account and I been trying for two days
dust2dust
You could pay by voucher or real time payments which would reactivate your services and then you could use SMS for the 2FA verification.
Then afterwards get support to change your registered email address. Remind them to change it in two places in their system
RossN
@atiller79
hi you  need to contact a customer service agent to reset or change your email
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
