Can't send text messages through public mobile - Error 332 (Android)
archibald88
Keep getting this error when I try to send SMS/MMS messages.  Happens with all contacts.
archibald88
Restarting phone seems to have worked, or perhaps just fixed on its own.  Thanks.
@archibald88 - try restarting your phone. EDIT, likely network related that may fix itself.
IF that doesn't help, try your SIM card into another phone to see if that helps.
Also, check for outages in your area:
@archibald88
first, try to click Reset All networks (Android)  and see if it works
If not, clear app cache for your message app.
if still does not work, download Google Message and set it as the default text app
