Can't send or receive test messages
04-20-2020 07:49 AM - edited 01-05-2022 10:27 AM
Just moved my service from Virgin, I am able to make calls but I am unable to send/receive text messages.
Phones
04-20-2020 11:42 AM
If your Virgin SIM card still working, continue to use it until it stops working which is the indication that Virgin had released your number to PM. Start using your PM SIM card.
Welcome to PM community support.
04-20-2020 09:54 AM
Hi, thank you very much for all of your help. I am very happy to be a part of PM. You stay safe to!
04-20-2020 09:43 AM - edited 04-20-2020 09:46 AM
@Bboultin your port is probably stuck, but this doesn't explain the inability to send texts, so your SIM may have also not provisioned properly. So at this time, the Moderators is your best answer. Keep an eye on the envelope, the mods answer will show up there. Once it does, you will be asked to verify your self service account, with your password and login. Doing this allows the process to continue.
You can also enable email notification to receive a private message notification sent to your email.
Go into your community account > my settings > PREFERENCES > Private Messenger > enable "Receive email notifications for new private messages" > Save
Welcome to PM . Stay safe.
04-20-2020 09:38 AM
Thank you for outlining the steps. I followed them easily. But still it did not work.
04-20-2020 09:31 AM
@Bboultin well even if you are not tech-savvy it is good to hear that you were trying what others suggested. At the end of the day the best first response is try to get get help from SIMon if that doesnt work ask in the community and lastly reach out to the MODs. You can also search in the community if the topic has already come up.
cheers and have a great week!
04-20-2020 09:17 AM
@Bboultin To reset the network settings of your phone, you have to follow these steps
- From the Home screen, swipe up on an empty spot to open the Apps tray.
- Tap Settings > General Management > Reset > Reset network settings.
- Tap Reset settings.
- If you have set up a PIN, enter it.
- Tap Reset settings. Once complete a confirmation window will appear.
Enable data( use link to see how
https://videotron.tmtx.ca/en/topic/samsung_galaxya5/turning_mobile_data_on_and_off.html#step=1)
Restart your phone, re-enter your wifi password if applicable, and try to send an mms(picture) message. Let us know if this works. Thanks.
04-20-2020 08:50 AM
Hi, thank you for your reply. I am not very tech savvy I have tried to your suggestions I most likely am not doing it right. I have submitted a ticket.
04-20-2020 08:26 AM
@Bboultin do you still require help? Thanks.
04-20-2020 08:06 AM - edited 04-20-2020 08:08 AM
@Bboultin try a network reset. Enable data, restart your phone and try sending an mms text message.
04-20-2020 08:05 AM - edited 04-20-2020 08:15 AM
Yikes that's a long time. Try doing what @gblackma said.
04-20-2020 08:03 AM
Galaxy A5 (2017)
Model - SM-A520W
Thanks
04-20-2020 08:02 AM
Hi, thanks I did the port yesterday afternoon. I can make calls but not texting
04-20-2020 07:58 AM
If it has been a few hours since your port then it is incomplete. You would need to submit a ticket to a moderator by clicking on the question mark on the bottom right.
04-20-2020 07:51 AM - edited 04-20-2020 07:56 AM
@Bboultin How long has it been since you ported your number from Virgin. It takes 2 to 4 hours for a number to port. Mabey a day. The port might also be incomplete. Or stuck. If it is you will have to contact a modetator but I would like to know how long its been since you ported before you do.
04-20-2020 07:51 AM
@Bboultin what's the make and model of your phone? Thanks.
