Can't send MMS
BigDog87
I have the apn set up and have a 4g lte connection
If I use Rogers it works fine, but using public mobile I can't send an MMS. SMS and all other functions seem to work fine
I'm using a ZTE Axon 7 which is dual sim but I have my Rogers sim disabled
12 REPLIES 12
BigDog87
So... an update
Doing the steps mentioned before fixed the MMS issue........but it has removed the ability for the APN to be used for data 😞
Edit: Update.......nevermind. I added the APN again without the MMS changes and it allowed me to use the original APN for data while still using the modified settings to send an MMS
JaK
Your welcome @BigDog87
(My brother-in-law has a different ZTE model, he was never able to get MMS working either. Called him up when I saw the post, he's now good too 🙂 )
BigDog87
@JaK you are amazing! That was it
JaK
Hey @BigDog87;
Have you seen this post: http://productioncommunity.publicmobile.ca/t5/Discussions/Can-t-send-or-receive-MMS/m-p/67110/highli...
The user has the same phone and no MMS. The solution appears to be a special APn for MMS.
JaK
Ok, doesn't that rule out it an APN issue?
BigDog87
An update..... I also can't receive mms
BigDog87
@JaK data works fine
BigDog87
I have tried putting my PM sim in slot 1...didnt work
Did a factory reset just in case... Still didn't work ....
JaK
Hi @BigDog87;
Some dual sim phones have different capabilities for the 2 sim slots, have you tried swapping slots?
Also, is it only MMS that is not working, or is it all data?
Ionut
So you have LTe connection on PM network ? Usually the dual sim have some issue.
My phone have 2 Sim and if i put my Sim Card into 2nd sim card i don't have MMS and the data is only 3G.
Also can you confirm that you have this settings?
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
BigDog87
I have tried taking the Rogers sim out entirely... It still won't send. The apn is copy and pasted from the apn posted in the community here
NDesai
With the daul sim phones, there is always this kind of error. You will have to play around settings also try switching the sim slots. At the same time, make sure APN settings are correct.
