Can't remember my pin
Bang
@Bang
FYI - your Account (4 digits) PIN is different from your Voicemail  (4-15 digits) PIN.
Maybe try your voicemail PIN for your account PIN (incase it is the same, if it is 4 digits).
To reset your voicemail password, see here: https://www.publicmobile.ca/en/on/get-help/articles/reset-your-voicemail-password
Only one way to you fix it explanation to moderator Team and the are nice service the will 100% help you
you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • or you can send a private message to Moderator_Team by Click here
  • You’ll need to be logged in to your Community account for the link to work.
  • In your message put it, please include.
  • your account number,
  • your phone number,
  • your account PIN,
  • explanation to them nice Team and nice service
      Good Luck
Triguy
Check your text message history.  PM would have sent you a text message with your pin.
Otherwise, you would need to contact an moderator to rest it
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
